Front Bezel
Having been focused on the case badge, I discovered that I had overlooked something. As well as blue, silver and black, KOS-MOS' design also has several gold parts to it which I failed to notice and take into account for when designing the front bezel.
After sitting down and examining the front trying to work gold into the design I noticed the USB ports on the front. I don't know about you but I HATE front mounted USB ports. I can see why they are useful but unless positioned correctly they can destroy the look of a case.
Ripping the board out of the mount behind the front lower bezel, I sanded, primed and painted the mount black before covering it with some silver vinyl. That sorted the mount out, but I wasn't sure what to do with the pre-cut USB and audio holes in the metal itself. Then it hit me: get a plaque made with the project name on. Time to fire up Illustrator again.
![Project KOS-MOS Front Bezel](http://images.bit-tech.net/content_images/2005/09/project_kos_mos/31.jpg)
A simple but effective design. You can see my artist's impression of the final result on the right. I used the same miller from the case badge since he was cheap and did a good job.
While I waited for him to work his magic, it was time I worked a little of my own and finished off the front bezel. I drove down to Halfords (auto parts store) and bought two cans of a pearlescent black spraypaint, two cans of grey primer and some multi packs of wet and dry sandpaper.
The first step was to key the metal work with a coarse 450 grit to give the primer something to bite into. After the first coat, I let it cure over night before attacking the primer with some 600 grit - the idea was to smooth out the primer giving a nice base for the final paint to sit on. I only sanded it very gently as to not take it back to bare metal; when I exposed the metal I stopped and reprimed it, then sanded again. This carried on until I had a coat of smooth primer that didnt have any exposed metal. I used nine layers in total for the front bezel switching to finer paper when I needed.
The process went something like this:
Sand 450
PRIME
Sand 600
PRIME
Sand 600
PRIME
Sand 600
PRIME
Sand 800
BLACK
Sand 800
BLACK
Sand 1200
BLACK
Sand 1500
BLACK
Sand 1500
![Project KOS-MOS Front Bezel](http://images.bit-tech.net/content_images/2005/09/project_kos_mos/33.jpg)
While Apple lovers will cringe at this pic, my experiences with Apple and their products have left a bitter taste. My old iPod made a mighty fine sanding block instead of a mighty fine MP3 player.
A week later and the plaque arrived. I was planning on getting it gold plated but I had nightmares of people attacking my case with a chizel at a LAN in an attempt to get it off, so I polished it up and it made it passable for gold. I might get it plated later.
![Project KOS-MOS Front Bezel](http://images.bit-tech.net/content_images/2005/09/project_kos_mos/37.jpg)
With the plaque complete it was time to assemble the front and start installing hardware.
![Project KOS-MOS Front Bezel](http://images.bit-tech.net/content_images/2005/09/project_kos_mos/51.jpg)
This was it - it was almost complete. Now I just had to install the PSU and piping for the water cooling. Unfortunately, I got so carried away with the idea of completing the project that I kinda forgot that I had a camera and just charged on with the construction. So apologies, but I don't have any photos of this section.
